Understanding NTFS Hard Links, Junctions and Symbolic Links
Microsoft has implemented linking tools in its NTFS operating file systems since Windows NT 4.0 and Windows 2000. These links provide a convenient method for users to access their data.
Over the years Microsoft continued to improve these tools which can now be used to link files and/or directories together. The latest form of file link was initially introduced in Windows Vista and continues to form part of their latest operating system. In this article we will look at what these file links are and how they differ from one another.
What are NTFS Hard Links, Junctions and Symbolic Links?
Hard links, junction points and symbolic links are linking processes used by Windows to associate other files, directories or volumes. One of the methods to create file links is to use the command line program mklink:
  • To create a file hard link: mklink /H linkName target
  • To create a directory junction: mklink /J linkName target
  • To create a directory symbolic link: mklink /D linkName target
  • To create a file symbolic link: mklink linkName target
The following sections describe each type of file link in detail.
Hard Links
A hard link is a file that represents another file on the same volume without duplicating the data of that file. More than one hard link can be created to point at the same file contents. Hard links cannot link to a files contents that is on a different partition, volume or drive. Hard links on directories are not supported as it would lead to inconsistencies in parent directory entries.
Although a hard link is essentially a mirrored copy of the target file that it is pointing to, no additional hard drive space is required to store the hard link file. If a 1GB file is mirrored by 3 hard links, the total space used on the partition will only be 1GB instead of 4GB.
In addition, if any of the hard links or the original file(s) is/are deleted, the data will not be deleted, and the rest of the other links will still be able to access it. The file is only deleted once all links to it, and the file itself, are deleted. Changes made to the data contents via any of the hard links or the original will be propagated to the rest of the other items automatically (as they all ultimately point to the same file data) .
Hard links only work on Microsoft Windows operating systems that support NTFS partitions (Windows NT 4.0 or later) while FAT and older versions of ReFS file systems do not work with hard links. ReFS added support for hard links in V3.5.
An example of using hard links is when a user needs to have a file stored in two different folders. He could copy the file to the other folder and have two copies of the same file. However, twice the amount of storage space would be used. Also, if file contents of one file is changed, the other file will be outdated unless the newer file is copied over to replace it. Both issues could be solved with the use of hard links.
Junctions
Sometimes referred to as soft links, the function of a junction is to reference a target directory, unlike a hard link which points to a file. Junctions can be created to link directories located on different partitions or volume, but only locally on the same computer. It does this through the implementation of the NTFS feature called reparse points. Redirected targets in junctions are defined by an absolute path. An absolute path refers to a path which will contain the root element and the complete directory list that is required to locate the target. For example, \Main\Folder\report is an absolute path. All the information required to locate the target is contained in the path string.
Like hard links, directory junctions do not take up additional space even though they are stored on the drive partition; their function is to point to the original files in the original directory. Thus, it should be noted that if the target is deleted, moved or renamed, all junctions which point to the target will break and continue to point to a non-existant directory. Content changes from any of the junction links or the target will automatically propagate to the rest.
An example in which junctions are often used is on Windows Vista (and newer), where the name “C:\Documents and Settings” is a junction that points to C:\Users. Thus, older programs that reference hard-coded legacy file paths can continue to work in Vista and newer.
Symbolic Links
Symbolic links were introduced in Windows Vista/Windows Server 2008. An NTFS symbolic link is a file system object that points to another file system object. In simpler terms, it is a more advanced type of shortcut. Symbolic links can point to any file or folder either on the local computer or using a SMB path to point at targets over a network (the target machine on the remote end needs to run Windows Vista or later). They do not use any disk space.
A symbolic link can use either a relative path or an absolute path to point to its target. A relative path must be combined with another path in order to properly access the target file. For a detailed explanation between the difference of absolute and relative paths, please refer to Microsoft's documentation.
Symbolic links are transparent to users – they appear as normal files or directories. All applications will be able to recognize both the link and the target. Like junctions, symbolic links will become a stale link if the target is moved, renamed or deleted. The operating system does not check to see if the target exists.
For a basic overview of NTFS Permissions, basic and advanced, please refer to NTFS Permissions - an introduction.
Comparison table of hard link, junction and symbolic link
Hard Link
Junction
Symbolic Link
Supported OS
Windows NT4 or later
Windows 2000 & Windows XP or later
Storage requirement for target
Files must be on the same volume
Directories (paths) must be on local computer
Any path – local or remote, relative or absolute SMB file or path
When a hard link/junction/symbolic link is deleted using Windows Explorer…
The original file and other hard links pointing to it remains. If all associated links are removed, the data is deleted
Windows Vista or later: target is unchanged. Windows 2000, XP & 2003: target & sub-folders are deleted
Target is unchanged
The target is moved…
Hard link stays valid
Junction turns invalid
Symbolic link turns invalid
Relative path allowed?
Not applicable
Not allowed; path becomes absolute when saved
Allowed
Works on files?
Yes
No
Works on directories?
No
Yes
Examples of a hard link and junction
Data Links
Configuration Settings in SyncBackSE & SyncBackPro
In the backup and synchronization programs – SyncBack users are provided with numerous settings to choose how they want the program to handle these links if encountered during a profile run. To see the settings, modify your profile and go to Expert > Copy/Delete > Links. See the help file for details. SyncBack is capable of ignoring, copying and re-mapping the various types of links for files and folders, including file hard-links.
Summary
Now you have the basic knowledge on how hard links, junctions and symbolic links work in a NTFS Windows operating system, you are hopefully in a better position to recognize issues relating to them.
