UndeleteOnClick
Navigation:  »No topics above this level«
UndeleteOnClick
uoc-header
A Guide to Using UndeleteOnClick
UndeleteOnClick is a very simple to use file undelete utility for Microsoft Windows 7 SP1 (Windows 2008 R2) and newer (32-bit and 64-bit).
Any type of file can be undeleted / unerased, including NTFS compressed & NTFS encrypted files.
note
Note that you will not be able to retrieve files that have been deleted with DeleteOnClick using UndeleteOnClick.
UndeleteOnClick can undelete files from any NTFS or FAT (exFAT, FAT 12, 16, 32) drives, including: hard drives (internal and external); USB Keys; etc.
Program Information
File Name
DeleteOnClick_Setup.exe
Download Now
License
Freeware
Benefits
bullet
Recover compressed (NTFS based) files.
bullet
Recover encrypted files on NTFS drives.
bullet
Recover alternate data streams (ADS).
bullet
Restores using the correct creation & modification date & times.
bullet
Very fast MFT and FAT scanning algorithm, fast file undelete.
bullet
Undelete files on any valid logical drive visible by Windows.
bullet
Fully Unicode enabled so filenames in any language can be undeleted.
bullet
Fits on a small capacity USB key.
bullet
Gives chances of file recovery.
UndeleteOnClick is available from 2BrightSparks.
