<< Click to Display Table of Contents >> Navigation: FindOnClick > Using FindOnClick > FindOnClick Search by Date |
Using FindOnClick: Search by Date
Using these search parameters you can specify the last modified and/or creation dates of the files you want included in the search results. For example, you may only want to include files that were created today.
