<< Click to Display Table of Contents >> Navigation: FindOnClick > Using FindOnClick > FindOnClick Search by Size |
Using FindOnClick: Search by Size
Using these search parameters you can specify the size of the files you want included in the search results. For example, you may not want to include empty files in the search results.
