<< Click to Display Table of Contents >> Navigation: FindOnClick > Using FindOnClick > FindOnClick Search by Attributes |
Using FindOnClick: Search by Attributes
Using these search parameters, you can specify the attributes that files must have (or not have). Note that some attributes, e.g. Compressed, are only available on NTFS file systems. Also note that on NTFS systems there may be many files that have the ‘Not Content Indexed’ attribute set. This attribute is used by the Windows Indexing service (which is disabled by default on most Windows installations).
To only show folders in the search results, tick the “Do not show files” checkbox. Likewise, to only show files in the search results, tick the “Do not show folders” checkbox. For obvious reasons you cannot have both ticked.
