ScrambleOnClick
Navigation:  »No topics above this level«
ScrambleOnClick
soc-header
Scramble on Click
ScrambleOnClick is an easy to use program that allows you to quickly encrypt/decrypt a selectable section of text within any document that you wish to keep secure and private.
ScrambleOnClick works with email programs, and any Windows program where text is editable. For example text editors, word processing documents, spreadsheets, and many more.
Program Information
File Name
ScrambleOnClick_Setup.exe
Download Now
License
Freeware
Benefits
bullet
Encrypt any text quickly and easily using strong encryption.
bullet
Decrypt text which has been encrypted using ScrambleOnClick.
bullet
View the clipboard at any time.
bullet
Securely wipe the clipboard with a simple key stroke.
bullet
Use with any email program as well as document programs like Word.
bullet
Encrypt and Decrypt using either a keyboard shortcut, or via the ScrambleOnClick Tray menu.
bullet
Use the keyboard or ScrambleOnClick menu to encrypt or decrypt text.
bullet
An Encryption Keys Manager allows you to define different keys for friends, colleagues, business etc.
bullet
Start with Windows Logon.
bullet
The Master Password protects other people from using the Encryption Keys that you define.
bullet
Option to split the encrypted text into definable lengths of text. Great for email.
bullet
The keyboard Ctrl-C-C key press delay can be changed from 500 ms (half a second) to a second.
bullet
Password hints help you remember the password you have saved.
bullet
Complete help file, online forums, knowledge base, and FAQs.
ScrambleOnClick is available from 2BrightSparks.
