<< Click to Display Table of Contents >> Navigation: »No topics above this level« EncryptOnClick |
EncryptOnClick Freeware
EncryptOnClick Freeware is a program that lets you securely encrypt and decrypt files.
EncryptOnClick Freeware is like hiring your own highly experienced data security guard who ensures the files you want to keep safe and out of view from others, stay that way. The program is very simple to use and features 256-bit AES encryption. You can also optionally encrypt the Zip filename for complete security.
Program Information
File Name |
EncryptOnClick_Setup.exe |
License |
Freeware |
Benefits |
A very secure encryption method is also used (256-bit AES encryption). |
Files are both compressed & encrypted, which results in a smaller file. |
Optionally encrypt the filenames. |
Password protected. |
Will encrypt and decrypt single files, a selection of files or all files in a folder. |
Very simple to use interface. |
Can be used on a USB key. |
Fully Unicode enabled so filenames in any language can be encrypted. |
If the filenames are not encrypted then the encrypted files created by EncryptOnClick can also be decrypted using WinZip 9 and newer (provided the correct password is used). If the filenames are encrypted then they can be decrypted using SecureZip (provided the correct password is used). |
EncryptOnClick is available from 2BrightSparks.
