<< Click to Display Table of Contents >> Navigation: FindOnClick > FindOnClick For Advanced Users > Scripting > Functions > Regular Expressions |
function RegExFilename(RegEx, Filename);
RegEx: The regular expression to use.
Filename: The filename to compare with the regular expression.
Return value: TRUE if the filename matches the regular expression.
function RegExContents(RegEx, Filename, [DeepSearch], [CaseSensitive]);
Filename: The filename of the file to scan and compare the contents of with the regular expression.
DeepSearch: Optional (default is FALSE). If TRUE then do a deep search.
CaseSensitive: Optional (default is FALSE). If TRUE then do a case sensitive search.
Return value: TRUE if the files contents matches the regular expression.
function MatchesPattern(Pattern, Filename);
Pattern: A search pattern to compare the filename to.
Filename: The filename to check.
Return value: TRUE if the filename matches the pattern. A pattern can use *, ? and sets ([]).
<%SBCOPYRIGHT%>
