<< Click to Display Table of Contents >> Navigation: FindOnClick > FindOnClick For Advanced Users > Scripting > Functions > Filenames |
function ExtractFileName(Filename);
Filename: The full path to extract the filename from.
Return value: The filename, including extension. For example: ExtractFilename('C:\path\filename.txt') would return 'filename.txt'
function ExtractFileExt(Filename);
Filename: The filename to extract the file extension from.
Return value: The extension, including the period (.). For example: ExtractFileExt('C:\path\filename.txt') would return '.txt'
function ExtractFileDrive(Filename);
Filename: The full path to extract the drive from.
Return value: The drive or UNC path. For example: ExtractFileDrive('C:\path\filename.txt') would return 'C:'
function ExtractFileDir(Filename);
Filename: The full path to extract the drive and directory from.
Return value: The drive (or UNC path) and directory. For example: ExtractFileDir('C:\path\filename.txt') would return 'C:\path'
function ExtractFilePath(Filename);
Return value: The drive (or UNC path) and directory. For example: ExtractFilePath('C:\path\filename.txt') would return 'C:\path\'
function ExtractParentDirectory(Filename);
Filename: The full path to extract the drive and parent directory from.
Return value: The drive (or UNC path) and directory. For example: ExtractParentDirectory('C:\path1\path2\') would return 'C:\path1\'
function ExcludeTrailingBackslash(Filename);
Filename: The filename to remove the trailing backslash from.
Return value: The filename with the trailing backslash, if any, removed. For example: ExtractTrailingBackslash('C:\path1\path2\') would return 'C:\path1\path2'
function IncludeTrailingBackslash(Filename);
Filename: The filename to add a trailing backslash to.
Return value: For example: IncludeTrailingBackslash('C:\path1\path2') would return 'C:\path1\path2\
function GetTempFileName;
Return value: Generates a unique temporary file. Call GetTempFileName to generate a new uniquely-named temporary file. GetTempFileName actually creates a zero-sized file in a temporary location and returns its name. The caller must delete the file (using DeleteFile) after it is not used anymore.
function GetGUIDFileName;
Return value: Generates a new GUID that can be used as a unique file name. Call GetGUIDFileName to generate a new GUID suitable as a unique name for a file or directory. GetGUIDFileName only generates a file name and does not create a real file.
function GetRandomFileName;
Return value: Generates a new random file name. Call GetRandomFileName to generate a new random file name. GetRandomFileName does not guarantee a unique file name. If a unique file name is desired, use GetGUIDFileName method instead. To generate a real uniquely-named temporary file, use the GetTempFileName method.
function GetTempPath;
Return value: Returns the path to a directory to store temporary files. This directory is a system-managed location; files saved here may be deleted between application sessions or system restarts.
function GetHomePath;
Return value: Returns either the home path of the user or the application's writable scratch directory or storage, e.g. C:\Users\[username]\AppData\Roaming
function GetDocumentsPath;
Return value: Returns the path to the directory where user documents are stored, e.g. C:\Users\[username]\Documents
function GetSharedDocumentsPath;
Return value: Returns the path to the directory where documents shared between users are stored, e.g. C:\Users\Public\Documents
function GetCachePath;
Return value: Returns the path to the directory where your application can store cache files, e.g. C:\Users\[username]\AppData\Local
function GetPicturesPath;
Return value: Returns the path to the directory where user pictures are stored, e.g. C:\Users\[username]\Pictures
function GetSharedPicturesPath;
Return value: Returns the path to the directory where user shared pictures are stored, e.g. C:\Users\Public\Pictures
function GetPublicPath;
Return value: Returns the path to the directory where you can store application data that can be shared with other applications, e.g. C:\ProgramData
function GetCameraPath;
Return value: Returns the path to the directory where user pictures taken with a camera are stored, e.g. C:\Users\[username]\Pictures
function GetSharedCameraPath;
Return value: Returns the path to the directory where user shared pictures taken with a camera are stored, e.g. C:\Users\Public\Pictures
function GetMusicPath;
Return value: Returns the path to the directory where user music is stored, e.g. C:\Users\[username]\Music
function GetSharedMusicPath;
Return value: Returns the path to the directory where user shared music is stored, e.g. C:\Users\Public\Music
function GetMoviesPath;
Return value: Returns the path to the directory where user movies are stored, e.g. C:\Users\[username]\Videos
function GetSharedMoviesPath;
Return value: Returns the path to the directory where user shared movies are stored, e.g. C:\Users\Public\Videos
<%SBCOPYRIGHT%>
